How do I connect the mas air flow adapter plate to my mass air?
AN89HATCH
I am doing a blow threw mass air, and im wondering, how do I connect the adapter plate to my mass air with out getting boost leaks? If I put silicon around the mass air, and the adapter plate, will this make it so aI will not get a boost leak threw the mass air? for the guys that run blow threw mass air's what did you guys do?
S13ChucKAT
Car: asd
theres a few things you could try...
go to home-depot, in the electrician/electrical part.. there a thing that looks just like a MAF adapter plate.. (im using it on my MAF. so it works).. as well as a gasket that fits.. it is supposed to be use to house wires, when you come to a wall.. it screws into the wall, and gives the wires a place to enter.. either that, or get some gasket material, and put a very thin layer of it on the MAF adapter.. let it try, then press it against the MAF and make a very tight seal.
daniel240
Car: cars/motocross
i used RTV on mine and it did not leak. you can also use jb weld.
