how do i check my transmission fluid
x300zxturbox
Car: 300zx
my clutch is slipping right when my turbos kick in and i wanna check before i buy a new one try to save some money and also how do i check my slave cylinder and what else could it be and how do i check this?
x300zxturbox
Car: 300zx
nvmnvm i figured it out
Ill give u a head start
Car: 1993 Nissan 300zx Twin Turbo
how do u check it?
Wetmyson
Car: Z32
if your clutch is slipping it might be your clutch.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
lol, ok first of all the resivior for the hydraulic fluid for the clutch is located right beside the master cylinder for the brakes, and it used brake fluid, your trans has a plug on the side of it you have to pull out and put your finger in (yes really) and it uses gear oil, wouldn't want you to all gear oil to your master cylinder :0
and if your clutch is slipping it has nothing to do with any of the fluids, ust means the clutch is worn down
