DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Sun Jan 26, 2003 8:19 am
The only trick is to have done it before at least once or twice, or to have someone there who's done it. Most people are scarred for life, and can often be seen wandering around their garages during the ordeal, dazed and confused, mutering phrases such as "rubber hoses" and "harness clip". Seriously, do a search on it; you'll be able to find some tips scattered about. I think Landtodd posted a good thread recently. It is a bigger undertaking than it initially looks. If you're going for it (and if you've started, then yes you are), you'll want to consider ordering a bunch of parts now from Scottsdale to replace while you're in there rather than do the job again in 6 months when your hoses crack. Again, do a search for the parts needed. Scottsdale does have an under-plenum hose kit, though it may not have all that you'll need. You'll also need to order new rubber plenum seals. Take good notes and digital pictures.
