gwhunt23 »
https://forums.nicoclub.com/gwhunt23-u86883.html
Sun Apr 20, 2008 5:47 pm
The fuel filter is right above your rear differential. To change it, do the following:
Open the fusebox and pull out the fuel pump fuse. It should be in the exact middle of the 3rd column. Check against the chart printed on the side of the fusebox housing.
Start the car. Wait for the engine to die (remember, there's no fuel). Once it dies, start it again until you can be sure fuel is completely out of the system.
Now you have released pressure from the fuel lines and can safely remove the inline filter without spraying gasoline everywhere.
Crawl under the rear of your truck and look against the bottom of the floor paneling for the fuel filter. Should be near the rear differential. Take a Phillips screwdriver or a 10mm wrench to remove the mounting bracket.
Now remove the clamps holding the fuel lines to each end of the filter.
Note direction of fuel flow before removing completely.
Reinstall with new filter in proper direction. Replace line clamps, bracket, and fuse and start vehicle. May take a few extra cranks to re-pressurize system.
Planning on doing a pic guide when I change mine in a few weekends.
Good luck!
