How do i change my tps?
nationall
Car: 93 240sx
i need to change my throttle positioning sensor on my 93 ka24de. if anyone could share any information that would be great. thank you.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
nationall wrote:i need to change my throttle positioning sensor on my 93 ka24de. if anyone could share any information that would be great. thank you.
there are many ways to try and do this...but i found the easy way is to drop the inatake manifold....the the sensor is super easy to get to...if you havent allready removed the intake many..there are a few supporting brackets that are a pain to get to..once you remove them..and fix your tps..you dont nessesarly need to put those brackets back on...ive run with out em for a few years not with no ill effects...it allso makes taking the manifold off easyer in the future...i dont have my fsm infront of me..but if i remeber correctly..you need to adjust the tps to (0.50v) or sumpin like that once its installed..you need to verify that thou..good luck.
