how do i change my belts?
illestcreatedsoul
Car: 1990 s13
how do you change all three belts on a s13 with ka24e motor?
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
loosen the tensioners on the power steering pump, alternator, and air conditioning pump.
illestcreatedsoul
Car: 1990 s13
do you have a diagram of it or know where i can look at one, sorry but i just got the car and im jus getting used to it
RedSVTFlareside
Car: BMW M3 & 1992 white S13 coupe'
you use some wrenches and just loosen the tensioners. I can't break it down any more than that. Did you even look at it yet?
huntin5L
You have to loosen the tensioners. The bottom right most pulley, the tensioner is behind the pulley. The other tensioner is on the alternator and the last one i believe is the upper right pulley.
illestcreatedsoul
Car: 1990 s13
huntin5L wrote:You have to loosen the tensioners. The bottom right most pulley, the tensioner is behind the pulley. The other tensioner is on the alternator and the last one i believe is the upper right pulley.
thanx for being more specific bro that madd helped me out... but do i need to take off the fan? or is there any easier way to get to the bottom tensioner
180fan
Car: 89 fastback
nah you can work the belts around the fan.
hnsenter
if it's ur first time especially if everything is completely stock, i suggest u take off the fan. them factory bolts a ***** to take off. Had to use a pipe to add more torque to ratchet to pull it off. follow the belts.. look at the pulleys and the bolts that are connected to it. not very complicated.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
These should help zerothread?id=227666 factory service manuals.
240marcuSX
Car: E34 525i
E46 M3
its real easy. as Ive done this 439283728 times. Im sure I can give you instructions based on memory.
1. Remove vacuum lines from intake pipe2. disconnect intake pipe from intake element.3. remove intake mounting hardware4. remove intake pipe.5. disconnect upper radiator hose6. remove fan shroud, fan (makes it easier)7. loosen tensioners8. loosen alternator mounting bolt, but do not remove all the way9. remove belts10. replace with new belts11. reverse process.
You can screw up two of the three belts on the KA24E, and it will still run, lol. albeit without P/S or A/C.
