kim »
https://forums.nicoclub.com/kim-u15840.html
Wed Apr 20, 2005 8:07 pm
Theres no real way to adjust it, when you open your fuel door you should see a plastic nut holding the opening lever. The plastic nut should be tight. Your cable might not be attached properly. Take off the trunk liner on the side that has the fuel door. you should see the latch attached to the Fuel door. there should be 2 hard plastic gromets on the cable attached tot the latch. Most of the times they slip off, just make sure they are on right. I had the same problem, the 2 plastic gromets was not properly attached to the latch had to push it as hard as I could.Sometime the latch itself is broken. I have a spare latch if you need it I give it to you.
