How do I adjust the idle on an SR20DET?
pumpiniron
Car: 1990 Nissan Sileighty SR20DET
I already did a search for it and couldn't find it so don't bother telling me to search. I'm curious how I adjust the idle on an SR20DET redtop. I don't know if it's on the throttle body or somewhere else.
SRraider
Car: 92 240sx coupe w/ SR20DEt swap, 02 chevy camaro
It's on you idle air control valve thats on your intake manifold. You'll see a screw on top of it that you can adjust the idle with.
jr_ss
Car: 95' S14
To add to SRraider's post, turning the screw CW will slow or lower the rpm's at which the engine will idle. Turning the screw CCW will speed-up or raise the rpms at with the engine will idle.
CW= clockwise; CCW= counter clockwise
onecrazyfoo4u
Car: 03 Type S
The IACV is on the back of the intake manifold, inbetween the firewall and intake, correct? How do you reach in there to adjust it, or even take it off to clean it? Looks like it'd be a pain.
