180fan »
https://forums.nicoclub.com/180fan-u3602.html
Sun Nov 20, 2005 11:57 pm
Rebuilding the block without proper tools can make it very difficult, especially when having problems like spun bearings and such.
With a problem like a spun bearing, it can get very difficult and tools become very expensive very quickly. Let alone knowing how to use those tools and assuming you don't have anything like line bore issues where the machine gets pretty big and pretty expensive.
Are you familiar with stuff like micrometers and bore gauges? I used those two tools quite a bit during my rebuild including a few other things like a buret to figure a few other things out.
If you're not familiar with how to use those tools and how to read the measurements, what measurements are relevant to your build, etc. I'd take it to a machinist to do the build at least on just the bottom end, although the head should be checked over too.
