inatall its self is not hard, there are alot of bolts like 18-20 that hold the plenum down, and there is a torquing pattern to follow. make sure you have time set aside to do it right. This not a job you want to rush, else you end up with a air leaks and Error codes.
The install will inprove mainly the Mid range power of the car 3500-5500 RPMS. right where its needed
Also the engine sound will be louder and more throaty
