How did you hoist your engine?
newdude1
Ive been looking around and cant really find what points is good to hoist your engine? Some say chain it around the intake manifold and around the exhaust manifold, then I read engine slingers. Its it safe to chain it around the intake manifold?
Where and how did you chain up your motors?
Stripes
Car: hatch, coupe
newdude1
lol not really what i was looking for. But seriously whats the lift points on the s14sr?
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
We ran mine through the exhaust and intake manifold runners on both the KA and the SR.
Slammed95S14
Car: 2001 R50
It's really easy, just use your common sense and even out the weight.I put squares around potentional spots you could use.
Justin35ll
Car: s13 coupe sr20det
Yeah, I just pulled my Ka about half hour ago lol just wrapped it around the intake and exhaust manis, but I was also wondering what to put it on the sr because I just replaced the intake and exhaust gaskets and **** didn't want to risk holding it by those.When I swap it in this weekend I'll let you know what I decided to do.
sidewards
Car: 95' 240sx sr'd, 00' Sierra 1500, 94' cbr600 'fighter
ratchet straps around pretty much any part do a good job.
positron1
I had a shiny new powdercoated valvecover and a shiny new turbo mani and freshly painted exhaust manifold that I didn't want scratched up so I put a towel around them so the chain would not make contact and nothing was marked. Just look at where the chain will make contact.
Sil80315
Car: 1991 Nissan 240sx
Ive seen a few SR's that came with hooks that could be unbolted after. but yeah usually a good 500lb ratchet strap around the first intake runner and the last exhaust runner on the manifold will do the trick.
japslapsilvia
Car: 90 s-13
i have always uesd the motor mount perches
newdude1
Are these good to use?
huggys13coupe
Car: 91 coupe
Slammed95S14 wrote:It's really easy, just use your common sense and even out the weight.I put squares around potentional spots you could use.
like this lol
newdude1
I dont have anything to hook to the bolts. Thats why Im askin if the way I have it now will work.
redsx13
Car: 93 240sx 03 350z
newdude1 wrote:I dont have anything to hook to the bolts. Thats why Im askin if the way I have it now will work.
Your setup looks akward, you have to pick points on the corners of the motor opposite each other, plus once its on the hoist you really need some control over the thing to get the tail (trans) in.
step 1. pick 2-4 solid bolts to hoist from (one on each corner of the motor is best)
step 2. get some chain (big enough for the bolts to fit through, but not all the way through)
step 3. bolt the chain to the motor, and lift from the center.
newdude1
the way I have it worked excellent. lol
SpeedRacer1
Car: 1990 240SX, G35
You can still order the stock engine slingers for the SR from Nissan seen in the pic below red and green. Though they mount in places more suited for just lifting the engine, you can get an idea of where to put chains/cables.
Justin35ll
Well I "tried" putting in my sr tonight (need correct engine mount) but anyway I hoisted the sr by the lower bracket under the intake manifold and the engine mount bracket on the exhaust side. Seemed to angle the engine good as I was able to pull the motor back out by myself and it seemed sturdy
burntricer
Car: 90 S13 SR20DET Redtop
NO! never, ever, ever lift from those points that were posted with squares around them..those bolts are 8mm bolts with a 10mm head...would you hold yourself up with an 8mm piece of steel? thats basically what you would be doing, the strength just isnt there.
you need to go atleast 1 inch long by 12 mm bolt
go with the studs into the head. or around the intake/exhaust runners.
painengaged
Car: s13 sr20det
i think slammed did the best even it out 2 bolts and shes out thats how i did mine. i dont like the sling around the intake.
