Cleveland180 »
https://forums.nicoclub.com/cleveland180-u25891.html
Tue Feb 09, 2010 6:14 am
Ok So I have been thinking, I have yet to tighten the bolts on my mounts, for those you are unfamiliar with the McKinney mounts, they have four semi vertical bolts for the mounts and then two horizontal bolts on that bolt into the stock crossmember, do you think that I can scoot my motor back a bit by using the bolts to pull my engine back? or do you think the mount bushings will just flex to accommodate the extra force? I am just trying to brain storm here, and I don't think it would give me all that much space, but is it worth counting on ? I want to do as little trimming the to fan as possible because I know that fan tips are pretty important in affecting the way the air flows. Ideas?
On a side note, I have seen the new rad support made by one of the members, but I have no welding experience so that is kinda out of the question.
