Here is my scenario. It started with just the passenger side headlight not going down but going up fine, then after about 6 months both headlights would pop up no problem, but the only way to get them to go down is to pop the hood and manually turn the motor (I know we have all done this at some point).
The list of common culprits from reading previous posts seem to be:
-the switch on the steering column
-relays
-timing control module mounted behind the driver's side left kick panel
-the motors
Someone mentioned a blue plug with a white cap behind the radio being the problem with their headlights but not much follow up information was given.
It was about 2 years ago when I checked all the relays and took apart the switch and cleaned all the contacts. I even got my hands on a brand new switch but that did not make the headlights retract.
Today I inspected the timing control module, which had no obvious signs of failure. I also removed the right side headlight motor and took it apart and cleaned the brushed and tried to clean the contacts. Plugged the motor back in and it only moved when the headlight was popped up, still would not go down. Maybe the relay inside the motor is bad? The contacts had a lot of grease one them when I opened up the motor. I wiped them as clean as I could but my hopes were still squashed when the problem persisted.
Here are some pictures of the motor.
Please share what your specific headlight problem was, and how you fixed it. And if anyone has any insight on my headlight problem I would greatly appreciate it. Thanks.
