krayton »
https://forums.nicoclub.com/krayton-u8223.html
Wed Feb 04, 2004 6:54 am
look near the back where your ignitor chip is. might need to look under the center cover. theres a little wire that loops. mine was Black/Red. You can pull it out a bit and just hook your timing gun up to that. Might be hard to find but just know its there.
Get that hooked up, let it warm up. Unplug the TPS and shoot. Farthest notch to the left (should be orange or something) is TDC. Then adjust to 15BTDC (every notch to the right is 5 degrees BTDC). You can adjust it by moving the CAS on the front. Pretty sure you turn it clockwise to move the timing back.
If you need more help finding the loop let me know. ill take a pic.when i had mine at TDC it ran like total ****. also stalled and would bog like no other if I tried to give it throttle. Setting the timing fixed everything. So try this first, sounds like itll take care of your problems.
