adidas2go »
https://forums.nicoclub.com/adidas2go-u78832.html
Wed Nov 19, 2008 5:18 pm
Really? I thought you could tint the front window above the AS1 line?
This is from the DMV of California handbook section 26708 (c) :
(a), transparent material may be installed, affixed, or applied to the topmost portion of the windshield if the following conditions apply:
(1) The bottom edge of the material is at least 29 inches above the undepressed driver's seat when measured from a point 5 inches in front of the bottom of the backrest with the driver's seat in its rearmost and lowermost position with the vehicle on a level surface.
(2) The material is not red or amber in color.
(3) There is no opaque lettering on the material and any other lettering does not affect primary colors or distort vision through the windshield.
(4) The material does not reflect sunlight or headlight glare into the eyes of occupants of oncoming or following vehicles to any greater extent than the windshield without the material.
(d) Notwithstanding subdivision (a), clear, colorless, and transparent material may be installed, affixed, or applied to the front side windows, located to the immediate left and right of the front seat if the following conditions are met:
(1) The material has a minimum visible light transmittance of 88 percent.
(2) The window glazing with the material applied meets all requirements of Federal Motor Vehicle Safety Standard No. 205 (49 C.F.R. 571.205), including the specified minimum light transmittance of 70 percent and the abrasion resistance of AS-14 glazing, as specified in that federal standard.
(3) The material is designed and manufactured to enhance the ability of the existing window glass to block the sun's harmful ultraviolet A rays.
(4) The driver has in his or her possession, or within the vehicle, a certificate signed by the installing company certifying that the windows with the material installed meet the requirements of this subdivision and identifies the installing company and the material's manufacturer by full name and street address, or, if the material was installed by the vehicle owner, a certificate signed by the material's manufacturer certifying that the windows with the material installed according to manufacturer's instructions meets the requirements of this subdivision and identifies the material's manufacturer by full name and street address.
(5) If the material described in this subdivision tears or bubbles, or is otherwise worn to prohibit clear vision, it shall be removed or replaced.
