How could I lean out my fuel injectors w/o a tune
RightRyan
Car: 1994 300zx TT FairladyZ
484rwhp @ 25psi
I have a 1994 300zx TT with 740cc injectors on top of many other things, i also have the JWT ecu from Z1. I dont have the money to spend on an AEM standalone so for now I'm looking for a way to not run so rich 24/7. If i had a MAP sensor I could wire a switch to control voltage and in turn, inject less fuel when I'm cruising at highway speeds and switch back to normal when I want performance. Any ideas??
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
Why would you want to risk detonation tho?
RightRyan
484rwhp @ 25psi
Well I wouldnt be risking detonation considering im running TOO rich as it is. I'm not talking about running too lean, I'm just wanting to dump less fuel all the time
nissanfreak12
Car: 92 300zx 2+2 TT
Is your ECU tuned to take the 740CC injectors? How do you know your running too rich all the time? Could be a tuning issue, or an O2 sensor issue, CTS sensor issue. What are reasons to run leaner?
