how come u wouldnt want side feed injectors over top feed?
mmatl16
Car: 240sx rb20 swap
i was thinking about putting rb25 injectors in my rb20 but i read that i would need the fuel rail to......also what size are the rb25 injectors and why wouldnt i want side feed?
gawdzilla
Car: none
side feed is less common and more expensive.
mmatl16
u wanna be a little more descriptive since i got rb25 fuel injectors and fuel rail for 20 bucks
Imissmyturbo
Car: Car's, Turbo's, sking
Side feed can run higher duty cly since the coil is surrounded by fuel and that keeps them cooler. Other then that they are exspensive to buy.
mmatl16
so should i switch my rb20 injectors for rb25 injectors or what?
hannibal
Car: Red Line to Glenmont
if you need bigger injectors and you have the RB25 lying around, then go for it.
mmatl16
IWannaS15 wrote:if you need bigger injectors and you have the RB25 lying around, then go for it.
thanks i prob will then.
do u know what the cc difference is off the top of ur head
rb20-270 ccrb25-?
Bluefire
370cc
mmatl16
damn....really? well im def changing them now
BoostFab
Car: S13cp, S13fb, S14z
search on ebay for rx7 high impedance sidefeed injectors....there are plenty of 550cc for cheap....bunch of sr guys are going this route.
hannibal
The purple top FD injectors BoostFed mentioned could work too. But you would still need the RB25 rail.
FC turbo injectors are top feed 550cc. But I have a hard time figuring out which are high impedence (I think its the 88-91, TurboII??)
mmatl16
so does anyone think i can get em for the same price i got rb25 injectors and the rail?
(20 bucks)
BoostFab
i say screw it..stick with the top feed rail....just get yourself a set of high impedance top feed injectors.. and you can always change out the injectors later on without swapping out fuel rail. top feed injectors are cheaper and abundant
