V I |7 E /2 »
https://forums.nicoclub.com/v-i-7-e-2-u7383.html
Wed May 21, 2003 9:22 pm
Power shifting is when you let off gas, and shift with clutch still in. It doesnt damage clutch, if you screw up its bad for synchros tho. Just take the extra .1 sec and use the clutch, youll be glad u did.I had a Saab and powershifted all the time cuz it went so easy, but even w/out grinding the trans started to fuk up. It would grind the 1-2 shift even when i used clutch.
The trick to doing it tho, is let off gas and immediately shift and dont be afraid to push it in with some guy juice.
