How come 2.5 tops at 113 ??????
All things Altima Coupe.
PHENOMenalVinyl
Car: 08 altima coupe 2.5 mt
i dont understand y the 2.5 tops at 113 i was goin on lie yesturday out east n i toppped at 113 and was dissapoointed i knew it did this already but the sad part was i was only in 5th i mean it was at like 4500-5000rpm's n it tops i feel like it has more power y did they do that????? and does the 3.5 do it, or does it top in 6th ????
n i know i should of got the 3.5 yes but cant bc of gas so i dont need the u should of got a 3.5 lol thanks
jdshift
Car: 2019 Nissan Altima
2015 Nissan Altima 3.5
2014 Infiniti QX70 S 5.0
It's a thing called a governor, should have gotten a 3.5
jdshift
Yes the 3.5 has one as well I should add
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
PhEnoM78 wrote:i mean it was at like 4500-5000rpm's n it tops i feel like it has more power y did they do that?????
The governor for cars in America are set at the original tire speed specs. The original tire on the 2.5 is a 215/60-16 94S. S is the speed rating which is controlled by the DOT. S = safe speeds up to 113 mph, therefore the governor is set at 113. The 3.5's come with 215/55-17 94H. H= safe speeds up to 130 mph. Therefore the governor for the 3.5 is set at 130. Make sense now?
PHENOMenalVinyl
yea that does but they dont have an ecu yet rite but wen they do would that change the top speed setting???????
dldjros69
Car: 2012 Evo Gsr
A/C 2.5 Turbo 6MT (SOLD)
adidas2go wrote: set at the original tire speed specs.
Good to know, thanks for the info adidas.
That is weird how that works out, wow so that means that my car will only do 113mph, lol
I thought the cvts were governed at 113, and the 6mt at 125 or something like that. guess i was wrong.
adidas2go
yes, an ecu upgrade would lead towards performance upgrades which raise RPM levels, remove the governor, increase fuel pressure. That kinda thing.
D-Roll
Car: 08 Nissan 350Z Touring Coupe
Well said Addidas
altimacruiser
Car: 2008 Nissan Altima Coupe
I have gotten 135 out of mine with CVT in manual, with the Injen Intake. 3.5 only way to go.
PHENOMenalVinyl
they dont have one yet though rite ????? and can u get the governer taken out or sumtin if they dont have an ecu yet?????
adidas2go
Stillen is working on making there already popular QR25DE piggy back, the QR Pro, produce in the 2.5 Altima Coupe. I'm not sure however if their system removes the governor or not.
altimacruiser wrote:I have gotten 135 out of mine with CVT in manual, with the Injen Intake. 3.5 only way to go.
Right, the governor is at 135, Im sure Nissan can raise the governor to 135 without the DOT caring. Cause who is supposed to be going 130 anyways, ya know?
08altima35
Car: 08 Nissan Altima Coupe SE 3.5 6Spd Manny Artisan Turbo Dark Slate
adidas2go wrote:Cause who is supposed to be going 130 anyways, ya know?
i could think of a couple people including myself and yourself adidas.
PHENOMenalVinyl
i would love to but of course im not lol
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
when your car gets finished, you gotta come on out to Cali... I wanna see you and adidas2go race (legally at a track)... that would be the first ever race between a Manual turbo A/C and a CVT turbo A/C... (has to be since Adidas will have the only CVT turbo 3.5 A/C in existence... well at least that we know of)
my guess is that, all things considered, in a quarter mile with the same amount of boost, the CVT would win since it would not lose power like the turboed manual when shifting gears... what do you think? In any case, I can't wait to see both of your cars finished... when will they be finishing up your car anyway 08altima35? ?
adidas2go
would be a fun race, but its a hike for either one of us
this is true
08altima35
when jwt comes out with their internals, clutch, flywheel, etc i should be able to run 13 psi for racing at the track. that will be wicked fast, but launching is going to take some serious skill in a fwd. adjustable coil overs could help out with the launch and gear change squat, but only so much. if adidas and i meet up and race we will have to first race from a 20 roll and then from a stand still. i think he might have the advantage on a 20 roll if he can keep his rpm up, but i think i'd have the advantage at a track from a stand still because of throttle control that comes with having a clutch. whatever the outcome it would be interesting all the same and hells yeah to boosting the altima coupe regardless of transmission.
rjdmmfl1
08altima35 wrote:when jwt comes out with their internals, clutch, flywheel, etc i should be able to run 13 psi for racing at the track. that will be wicked fast, but launching is going to take some serious skill in a fwd. adjustable coil overs could help out with the launch and gear change squat, but only so much. if adidas and i meet up and race we will have to first race from a 20 roll and then from a stand still. i think he might have the advantage on a 20 roll if he can keep his rpm up, but i think i'd have the advantage at a track from a stand still because of throttle control that comes with having a clutch. whatever the outcome it would be interesting all the same and hells yeah to boosting the altima coupe regardless of transmission.
well tell jim wolf to get their a$$es in gear .... you guys can have the speed... i'll keeps my sounds.....
adidas2go
Thats gonna be way faster than me. I'm not trusting this CVT with anymore than 7psi. Your drive train is only as strong as your weakest link So no release date for your coupe yet huh?
nightrain
Car: 2008 3.5SE
adidas2go wrote:yes, an ecu upgrade would lead towards performance upgrades which raise RPM levels, remove the governor, increase fuel pressure. That kinda thing.
I'm sure there's an easy way to just override the top speed without replacing the ECU... For Motorcycles, it's called a TRE. I have one on my Suzuki but since I haven't had the need to go over 185 mph, the current top speed limit for motorcycles, I really haven't had a chance to test it...
adidas2go
Theres really not. Its all computer programming in the ECU. Either a piggyback system has to override the ECU or the ECU has to be "reflashed", a process of erasing the ECUs' coding and reprogramming it.
08altima35
i've spoke with and emailed the jwt engineers and they have plans to make stronger internals, clutch, and flywheel for the a/c's, but it's prolly not going to happen until sometime late this year or early next.
adidas2go wrote:Thats gonna be way faster than me. I'm not trusting this CVT with anymore than 7psi. Your drive train is only as strong as your weakest link So no release date for your coupe yet huh?
if we ever race of course will be boosting the same psi. is your kit gonna have a dash mounted boost controller?i'm hoping i'll be free on wednesday to go pick her up. i have the bodykit, and eibachs, sittin' in my garage ready for install. i gotta be done with both of those by june 6th if my cars going to make the dub show on the 7th which i've already promised my employer the car for their booth.
PHENOMenalVinyl
adidas2go wrote:Theres really not. Its all computer programming in the ECU. Either a piggyback system has to override the ECU or the ECU has to be "reflashed", a process of erasing the ECUs' coding and reprogramming it.
so its possible to reflash it ???? has anyone done that???????
adidas2go
Not in the dash, but we will be installing a boost controller in the cabin. most likely in the space beside the VDC button. So weird, I signed up for the DUB show a couple months ago for when it comes to LA in early August. I guess great minds think alike Your coupe should look very nice and clean by then
Reflashing the ECU requires the technology to reprogram it. The car itself is one big computer. If one module doesn't have the exact right signal its looks for from another, things go wrong. Reflashing an ECU takes an incredible amount of resources, technology, and permissions. As far as I know, only a few companies have the technology to break into and successfully reprogram the coding for late model Nissans. Stillen is one of them.
PHENOMenalVinyl
any way u think we could talk to josh and see if they could start doin this to some of our cars????? i bet loads of people would do it atleast the 2.5 owners
niztec
Car: 2008 AlTIMA COUPE
who needs to go that fast anyways? most states do have speed limit laws
adidas2go
PhEnoM78 wrote:any way u think we could talk to josh and see if they could start doin this to some of our cars????? i bet loads of people would do it atleast the 2.5 owners
Well this topic has been brought up to Stillen many many times over the past 4-6 months. Stillen is still testing and seeing if the QR Pro is fully compatible with the a/c QR25DE, like I stated earlier.
GryStrm
Car: 2008 Altima Coupe 3.5
...ummm duh cause the 2.5 aint a real coupe....like duhhh didnt you know...lol(i hope some of you realize this is a pun on some thread i read)
now...where in ****s christ did u find a spot on the lie to hit 113?...and what time..i live in queens...that thing is either a parking lot or a super trooper fest...its either the nassau guys or the million dollar a year suffolk county cats...or state...or nypd rollin in the hyped up chargers...or a combination of them,,,,heck i even saw a port washington police car pulling someone over the other day...we have state, city and even the small towns in the city getting in on the action on that road!....wait ...were you in stealth mode...i here they give u that in lieu of the extra liter for you 2.5!
heeroguy
Car: altima coupe 3.5
adidas2go wrote:Stillen is working on making there already popular QR25DE piggy back, the QR Pro, produce in the 2.5 Altima Coupe. I'm not sure however if their system removes the governor or not.
...... i had mine over 140 a few days ago
PHENOMenalVinyl
GryStrm wrote:...ummm duh cause the 2.5 aint a real coupe....like duhhh didnt you know...lol(i hope some of you realize this is a pun on some thread i read)
LOL man uve never been out east then lol i was at the outlets in like riverhead it was wen the lie starts/ends n theres NO cops at all over there i was racin a camero ss of course i lost but it was fun
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
I hit 110 on the loop parkway by my house as the sun was commin up...
NJ cops make LI cops seem like they are cub-scouts... I feel like the NJ LEO's get lashings if they come back from a shift with any tickets left in their book
