the origional mad tight stock ones they put on at the factory.ppctx wrote:lip of the wheel is ~5mm away from the stock strut
you talking to me?Koshin wrote:^^^what coilovers do you run?
Not sure about the fitment of your potential setup on an s13, but the minimal benefit of having an extra 20mm on your front tires isn't worth it imo...unless you run a spacer which i personally wouldn't do, but that's just me...pandapants wrote:It's ok if it rubs a little under load, it's not like your shock will explode or your tire will unseat.
