SpeedRacer1 »
https://forums.nicoclub.com/speedracer1-u311.html
Tue Feb 20, 2007 4:21 pm
That multilayer gasket should seal just fine without the spray. Spraying it unevenly can result in problems like leaking later. It is also hell to clean up if you do actually mess up the hg install and have to pull the head again.
If you already sprayed it then oh well, not the end of the world and your probably fine. If not leave it out and just install the gasket properly.
