How "clean" are the factory amps?
Post all your Nissan electronics, car audio and stereo questions here!
creophus
Car: 240SX SE & 200SX
I just installed new Alpine Speakers in my S14. It has the factory amp and head unit in it right now. I will be removing the factory HU and will put in an Eclipse 3403. Should I be worried about blowing my speakers with the factory amps? I am aware that they don't put out much power, but blowing speakers usually happens when the power is not clean, not when there's too much power.
Is it ok, to crank the volume or will I blow the speakers? The speakers are Alpine 170AS Type S.
bigE
Car: Anything dealing in cars.
You can turn it up, but once you hear distortion, cut it back, distortion kills speakers.
Eric
SmithSR
Car: 240sx
aka: replace them if you can afford to. factory amps were supplied to the vehicle manufacturer by the lowest bidder.
Simmsled
Car: TSI GTI - E46 325i
the factory amps provide low power that isnt very clean. so... if you are going to turn it up... i would cut the bass back (bass nob) and make sure not to hear distortion like BigE said
creophus
Ok. I know someone asked this before, but is it easy to bypass the amps? I don't want to have to re-wire the speakers that are in the door. It's pretty difficult looking to get wires through the door and back into the cabin. Right now I'm using an Eclipse 3403 with the factory wiring.
98TURBOKA
Car: HOME IMPROVMENTS-MOUNTAIN BIKING- EARNING MONEY-MOVIES
Distortion kills!!
Simmsled
Well, the way to do it is to get the lead wires going into the amp and match them with the speaker output wires at the head unit. When you see that they match, you can take those wires and attach new wire to them leading to your new speakers. Hope that helps, I bet one of the 240 guys might actually know the colors. If somebody has these, I will have them put into the install guide.
hibrid180
you can give me the amp ur not gonna use tho :D
creophus
Sure thing, make me an offer. ;)
Demonic240
Car: Computers, Car Audio, Imports
Factory Amplifiers don't generate enough head room to create distortion free signals at full volume ... and as everyone has mention, distortion kills speakers. I haven't looked at the builds on Factory amps, but I am also guessing there not anywhere near a Class A/B weighted amp ... producing a much cleaner signal.
Just my $0.02
