How can you tell if you definitely got a 248 Exhaust cam?
alkemyst
I installed one that was marked the proper color, but I don't know if it's definitely the right cam.
Anyway to tell? Idle seems a little more 'tough' but I also did an exhaust.
Thanks
Å
Rucca
Find true TDC with a degree wheel on the crank. Then measure how many degrees it is open for at .050" lift. Don't know if there are any markings to clue you off
alkemyst
Rucca wrote:Find true TDC with a degree wheel on the crank. Then measure how many degrees it is open for at .050" lift. Don't know if there are any markings to clue you off
Is there a way to tell by sound...there is one on streetfire, but it sounds like the guy did the 3 tooth method as it's majorly loping.
