how can you tell if the head is warped
getnrowdy23
Car: '95 sr20det 240sx se/2004 suzuki sv650s
car got kinda hot. radiator fluid came out of my s13 blacktop. not sure if i warped head. how can i tell without taking it somewhere... i searched no luck. the oil should be milky? i didnt drive it once it got hot so oil might not be milky yet. let me know thanks
912.0turbo
Radiator Fluid?LOLOL!!! Sorry but that was funny. If your head was warped you would have coolant in the oil or vice versa. Also you could run a compression check. Does your car smoke?
TunaFish
The only way to tell if your head is warped is to pull it and check with a flat edge and feeler gadges.
If the head is warped, the headgasket isn't going to seal and will have the same symptoms of a blown headgasket.
Depending on where the head gasket isn't sealing several things can happen
- Coolant can get mixed into the cylinders, and you will burn coolant- Coolant can get mixed into the oil (or oil into the coolant) and your oil or coolant resivour will turn milky brown- Coolant or oil can actually leak from where the head meets the block.
getnrowdy23
will the milkiness take effect immediately or do i need to let the car run a little to see if it mixes up? i dont think it is warped but i MUSt check
getnrowdy23
will the car run fine and boost fine if it is warped. car seems to run fine.
Florida240sx
You'd lose compression so you must be lucky.Check your oil to see if it's pure though.And do a compression test to be 100% sure everything is good.
getnrowdy23
aight cool, i just did a compression test a week ago so i know what i should get =)
s13sr20chris
i drove for months with a broken piston. hardly noticed it. be carefull.
spider_slayer
Car: S14 240SX
S13 240SX
just curious....i would think that if a piston was cracked it would eventually fail shortly after and break into little pieces and scroe the cylinder walls. also if it was cracked wouldn't you burn oil like a mother? i jsut don't see how it could run fine
s13sr20chris
it started with my compression on cyl 4 cutting about in half. i kept driving because the car was still really fast and i was planning to build a motor anyhow. as the months wore on she started blowing some oil out the breather filter and idling rough. i did not bother to do a compression test at that point. i just took her apart(with the block in the car) expecting to just do a re-ring and freshen up. nope, check my members rides gallery for pics. i blew the 2nd ring land. top land was fine. it left a gouge in the cyl wall that was cleaned up by a .020 overbore. that means the gouge was less than .010 deep. not bad for an iron liner being rubbed on by a piece of chromed steel at 7000+ rpm under boost!
spider_slayer
Car: S14 240SX
S13 240SX
i see......thats pretty sucky
