How can you tell if a cars chassis is stiff?
Mugen13
How can you tell if the car has a stiff chassis or if it just has really good suspension? Are there ways to test that out like say during a test drive?
B/c i was driving my sisters fiance's Accord w/ springs and shocks and i couldn't tell if it was the chassis that made it more responsive or if it was just that the suspension was better than my 240.
EazyBreazy
its unfair to compare suspendions when modifications have been made to one and not the other.
hannibal
Car: Red Line to Glenmont
Thats a real good question.I know that the chassis has to be stiff in order for the suspension to reach its max pontential. I would imagine if its a newer Accord, that it has a stiffer chassis than the 240sx and the springs/shocks also make a big difference
Hijacker
Car: '92 240sx Convertible
'94 F-150
suspension work comes down to a combination of suspension parts. chassis, dampers, springs, sway bars, etc.
performance parts such as the spring/damper combo he's done have increased responsiveness of the car. i don't know what work you've done to your car, but if it's stock, then it's no wonder why his feels better.
chassis-wise, accords are big and a little more loose than a sports coupe such as a 240. the only thing that the accord may have going for it is age. yours is probably a little older than it, so the metal might have moved/stretched and compromised the stiffness. you can get plenty of parts to stiffen it back up though. roll bars/cages, strut tower bars, ladder bars, etc
smokei
Car: 1995 Nissan 240SX SE with S15 front end.
2004 Lexus IS300
doesnt mugen make parts for hondas?... im not trying to flame just curious.... *cough*
but yeah you should really clue us in to what you have done to your car and how old it is with how many miles. Also another thing to consider is that the accord weighs a lot more than a 240 so if it has some sticky tires it should be be more stable feeling, but not quite as efficent. the responsiveness should be imagined as front wheel cars tend to be a little less responsive than a rear wheel car as far as steering response goes.
so in summary let us know whats up with your car and what your friend did to his accord. that should help us diagnos your quandry.
-dspeed kills buy a civic live forever
EnzoRWD
Car: 1997 Volvo 850 T5
best way to discover chassis stiffness:clipping curbs on a track. if u feel flex and sometimes mystery noises, u know stuff is twisting. i know mine is. AGX/spring, set to max damping, BUMpBUMPBUMP of those curbs, something gives. it muh old chassis
MarkEmark
Car: fully-built '95 240sx KA-T
Even with shocks/springs as stiff as possible, they'll still compress upon hitting track curbs; they're designed to do that so that the chasis doesn't need to flex to absorb the shock.
Have any of you considered wheel-flex? It's very possible...
I'm not really sure what chasis flex feels like, but I don't think I've ever felt it--I think my suspension is a pretty tight setup. I heard the cusco rear cross brace is supposed to do a lot to prevent chasis flex, and of course a roll cage would stiffen the chasis substantially.
My mom has a '98 Honda Accord EX V6 2 door, loaded (don't know if it has sport suspension or not--or if honda even offered that) with brand new sticky yokohomas, and my car would RAPE that thing on a track, any day. But it's not a viable comparison since mine has extensive suspension mods. The accord that I'm referring to weighs a full 500 pounds more than an S14 (mine, anyway). That's a lot of weight to carry into each corner; weight that I think will always make that car inherently less-responsive and nimble. However, her accord is a pretty nice handling car and I don't wish to underrate it.-it's stock suspension is pretty firm and sporty, but the extra weight becomes very evident. My car always handled better than it, by far, even when I first got it with just tokico blues/eibach sportlines
Kiwi_S13
TIRES!
sxseguy
Car: Makin' it go faster!
You could do a chassis deflection test.
Pick a measurement point at the front (such as the bottom of the frame rail by the wheel) and one in the rear, just make sure it's part of the monocoque chassis itself, and not a bolted on part.
Measure on a flat surface the distance of those point to the ground.
Jack up one end of the car until both tires on that side are completely off the ground and re-measure both points.
Subtract the unlifted from the lifted distance. The jacked up end is your reference/zero point. Do the same for the measuring point at the other end. If it's less than the reference point, it's because the chassis twisted/bent/deflected.
Using the distance between the points and the distance the chassis deflected, you can use simple math to calculate a percentage of deflection, or use trig to figure out the number of degrees of flex.
Hijacker
'94 F-150
you could also jack up just the nose (use a cross member) and try to open close the doors. If it's difficult/impossible, you have too much chassis deflection.
MarkEmark
sxseguy wrote:You could do a chassis deflection test.
You leave yur fancy edumacation outta this!
Good point sxse---glad to see someone knows their stuff. I think it'd be kinda hard to get an exact measurement though, but it's worth a try if someone's really interested in it.
