how can you tell if a 240 has ABS?
lovingmy240
Car: 240sx s15 95 base
hi, im trying to buy another 240 and i came across this 97 se. i checked out the car today but not sure if it has abs or not. please let me know if there is anyway i can find out if it has abs. thanks
onosqv
Car: '92 240sx Vert
pop the hood.
Look in the engine bay.
If the brake lines going from the master cylinder just go straight across the engine bay & down along the frame w/o connecting to an ABS box, then there is no ABS.
p1rat3
Car: 1991 Nissan 240sx
go down the road and slam on the brakes.
Chukidori
p1rat3 wrote:go down the road and slam on the brakes.
yeah XD
If the brakes go DU DU DU DU DU DU DU DU and vibrate the car.
You have ABS.
JeromeS13
Car: 2008 Subaru Impreza STI
Please don't listen to the previous two posts. Listen to broke. All you have to do is look under the hood for the monstrosity that is the ABS unit.
-Jerome
Chukidori
JeromeS13 wrote:Please don't listen to the previous two posts. Listen to broke. All you have to do is look under the hood for the monstrosity that is the ABS unit.
-Jerome
Well we all are correct.....either method will confirm if you have abs or not
onosqv
Car: '92 240sx Vert
But what if the car is equipped w/ ABS, but the abs is defective?
It's not like checking for ABS by popping the hood is all that hard...
ANVIL
Car: RB25DET S13.5
one of the quickest ways i guess is to cycle ur key and see if you have an abs light in ur cluster. another way take off one of ur front wheels and see if you have any electrical wires running to ur brake/hub area
driftneil
Car: A pile of cars.
Or tell me where the car is being as I live real close to philly and I will buy.............I mean check it out.
