Ha! got you http://nissaninfiniticlub.net/...o.jpgKamin wrote:RPM does not equal horsepower. just because it can rev to X thousand rpm dosent mean its makes power. i GUARNTEE the RB20 turbo doesnt make power anywhere past 6500rpm, so theres no point.
you guys used to own hondas didnt you?
hahaYellow4g63 wrote:Ha! got you http://nissaninfiniticlub.net/...o.jpg
smiley wrote:nope.... only a camaro lol was just askin , hey im curious... what mods do yuo require to spit flames lol...
saw a pic of a friends rb spittin fire
Head isn't the problem, it's the oil pump... his took a dump but I'm not sure if it killed the motor.Shocker wrote:better flowing turbo, cams, and a power FC, you can rock it out to 7500-8000, bobnissan was reving his to almost 9 k with stock head, i dont really recommend that, but his held up lol.
its more than a pump problemeh? wrote:Head isn't the problem, it's the oil pump... his took a dump but I'm not sure if it killed the motor.
displacment>revs ??? explain an F1 engine or a super bike ?? lol j/keh? wrote:displacement > revs. Also there is no reason the RB25 can't rev as high as the RB20.
It dosen't peak at 6500, it's after 6500 more like 6600-6700. That was after I added the Intakemanifold and FMIC.Kamin wrote:
haha
look at the curve. see how it peaks at around 6500?
thanks for proving my point.
also, what mods were those?
lol that extra 1-200 rpms... big deal there.. still point being said it isnt making any further power, a 25 chart will look almost the same with similair mods, just higher hp :P...Yellow4g63 wrote:It dosen't peak at 6500, it's after 6500 more like 6600-6700. That was after I added the Intakemanifold and FMIC.
LOLKamin wrote:RPM does not equal horsepower. just because it can rev to X thousand rpm dosent mean its makes power. i GUARNTEE the RB20 turbo doesnt make power anywhere past 6500rpm, so theres no point.
??? I'm just pointing out that it makes power past the 6500rpm point. My friends made 275hp with the same mods on his RB25. I wonder why he didn't blow me out of the water when we raced from a roll? I thought the RB25 could never lose lol.Shocker wrote:
From what I've seen you'll realize that issue after the oil pump problem is solved. I've seen a few oil pump gears cracked before the person realized they had a problem. Where each problem starts I don't know- all I know is keep your rev's below 8k.Kamin wrote:its more than a pump problem
its a design problem. it actually flows too much oil into the head wich in return leaves not enough in the pan and, violla. spun bearings
the pumps are an issue, but its a combo.
He was making more HP but didn't beat you badly enough. Why put the blame on the RB25?Yellow4g63 wrote:??? I'm just pointing out that it makes power past the 6500rpm point. My friends made 275hp with the same mods on his RB25. I wonder why he didn't blow me out of the water when we raced from a roll? I thought the RB25 could never lose lol.
Hmm you saidKamin wrote:seriously, 200rpm difference?
your manifold did that. and give me a break, 200rpm....and it LOOKS like a fake spike on the dyno anyway
your OVERALL CURVE ends at 6500rpm. making power past that will require money. lots.
I guess even with the evadence right in front of you ? You kill me hahaha.Kamin wrote: i GUARNTEE the RB20 turbo doesnt make power anywhere past 6500rpm, so theres no point.
And that proves the point further. Does the RB20 have some magic fairy dust that makes a 240sx go faster when it doesn't produce more power?Yellow4g63 wrote:I never said he beat me lol. It was the other way around.
psh.. ive still yet to a see a BPU 20 break 12's... i havent been to the strip in a while, but i ran a [email protected] with a 1.85 60 at stock boost on an 80 degree day. toad, got his 25 to a 12.5 at 10 psi.... once again lets see a BPU 20 do that..Yellow4g63 wrote:I never said he beat me lol. It was the other way around.
