How can i wire my coil directly? Cable damaged =\
Lopin18
Car: '89 Nissan 240SX Hatch KA24E
Well it seems my positive ignition cable from my wiring is bad, im not getting spark, and its the positive clave (it was cut by the ac compresor and i put it together again, no solder, but now im not getting any volts there, no spark.... and i tried rebuilding the connection again and nothing)
So i went out and the car lost all spark... tried rebuilding the wire and nothing.... no spark, and the cable was dead... so i had to run a wire from the battery directly to the coil`s positive plug... went home. but now what do i do???
Is there a safe way to wire it directly? or will i have to rebuild the stock wire and make it work again?
Lopin18
Bump! help!, noone can guide me how to wire it directly? T-T
........ Oh well... after reading a little google info i figured out that putting it directly will have the coil always firing, and the ECU wont be able to adjust timming the way it can, so ill have to dig the wiring and restore my cable back to funtionality.... >_< someone could have said something....
Modified by Lopin18 at 11:03 AM 2/13/2008
duveeka24det
Car: 240sx
I'm having a similiar prob... One of my buddies cut my wire harness where my coil wire connects to my coil and a few other wires...I Just want to know how to hook my coil back up so I can get fire
