That's an interesting design - did not know that's how these cars worked. Wow!VStar650CL wrote: ↑Sat Apr 26, 2025 10:09 amThere's a height sensor located near the left rear axle. The Nissan Consult3+ scanner has a utility for teaching the AFS controller the vehicle height, but you can also fool the AFS by simply bending the locator tab so you can rotate the sensor and change the rotational position of the linkage arm. Since you don't have any AFS warning light, to find out if the sensor is any good, disconnect the arm and move it up and down to see if the lights follow. If they do, the sensor is good and you can just change the position to get the focus where you want it. If the sensor is bad, replace it and then adjust if needed. Note that you should also check the wiring if the sensor doesn't respond, it lives in a bad place and can suffer from road-damaged wires or water intrusion into the connector. Lastly, if you do bend the locator tab, put a split or toothed lockwasher underneath the nut to make sure it can't work loose.
100%. I wish my car had auto-leveling. It has AFS (side to side during slow turns) but that's it. Factory HID.VStar650CL wrote: ↑Tue Apr 29, 2025 2:15 pmFYI, there are tons of Nissans and Infinitis with HID headlights but no leveling. Whoever told you that is wrong.
Nope. Some US cars do, like my brothers Audi and some Lexus' I've seen but not my '11 M56x.Q70sGuy wrote: ↑Wed Apr 30, 2025 8:14 pmIn Canada they all have electronic leveling… either through a switch or through the little sensor in the back to prevent blinding drivers when you load the back of the car. I thought the US was the same
When you turn on on your car it doesn’t do a little dance either headlights? (Down - up)
He's right, Ilya, I checked several EWD's going back and the leveling setup is integral with AFS. If you have one, you should have the other. Your ride may just have an inoperative sensor.
Hmm - interesting. I got this car with 32kmi on it back in Nov. 2014 and this has never worked. AFS has always worked at certain speeds (I don't remember when it does or doesn't trigger) but never auto-leveling during initial start up.VStar650CL wrote: ↑Fri May 02, 2025 4:07 amHe's right, Ilya, I checked several EWD's going back and the leveling setup is integral with AFS. If you have one, you should have the other. Your ride may just have an inoperative sensor.
Ahh, so you're saying my headlights would aim down if I had a cow in the back seat causing my car to do a "Carolina Squat"?
