i need to install new seals and or get replacement.
how can i tell from the outside what size this is.
car is 1990 300zx NA.
thanks
Ace2cool wrote:Most N/A's in 1990 came with 26mm. If you need to know for sure though, pull the rotor off, and measure across the back. It should be 280mm in diameter.
Well, actually all N/A's from 1990 came with 26mm, but some have since been upgraded.
Wrong measurement, you need to measure the thickness. All z32 have same diameter rotors, only difference is the thickness in the '90 NA.Ace2cool wrote:Measure the diameter of the rotor. Not sure I can make it any clearer than that.
Ace2cool wrote:Did you measure them?
ya dont drive anymore till you figure it out. I would try and bleed the brakes make sure there is no air in the lines make sure brake fluid is getting to the calipers. Did you use anti seize when you changed the pads? Sounds like your break is locking up and your driving around with the breaks on. make sure u didnt kink or twist the break line.KiDoZ wrote:Man i just drove car for a few minutes and afterward notice the brakes were smoking hot. Is that because of the brake fluid burning up or am i missing something. kits on the way.
t.mcginley.jr wrote:Does it sound like the pads/rotors are rubbing when you drive around? If so then your pistons are stuck and yes you will need to rebuild them. It isn't too hard to do. Your supposed to use compressed air to push each piston out, but mine were stuck SO bad that I had to use channel locks. Get your caliper off, put it in a vice, spray around each piston with some WD-40/PB blaster and let it soak a little. Then take some channel locks or whatever big pliers you have, put a rag around the piston and work them back and forth until they pop out. Just make sure you are grabbing the very edge of the piston and not the smooth/shiny part or else you'll scratch it (and it won't be able to seal right).
Your supposed to be able to use like 20 or so psi to pop them out, well mine weren't coming out with 120 psi so that should put things into perspective on how stuck mine were. When you get all the pistons out, soak them in something to clean them up and then just take out the old seals and put in the new ones. Also I forgot to mention taking off the dust boots around each piston, but they are only held on by little metal rings nothing hard to do. Make sure to clean the caliper fluid passages out with break cleaner too. Mine had some hardened crud in them that I'm sure was messing my fluid flow.
Ace2cool wrote:Tie rods most likely. Only way to figure that out is jack the front up and grab stuff and shake. Look for busted bushings as well.
thanksAce2cool wrote:Don't forget to get an alignment afterwards. That'll eat your tires up otherwise, unless you get 100% precise measurements.
