how can I tell if my infiniti is californian or federal for the ecu?
navyman_98_99
Car: 1991 q45
I need to find out what my 91 q45 is californian or federal, how can I do that.Thanks Mike
Rex
Car: None
I think Wes can tell you from the VIN.
Normally, if what I remember is correct, there's a sticker under the hood saying it meets California emissions standards.
navyman_98_99
Car: 1991 q45
no wonder why my car is not starting with the ecu's that I have. The car I have is california model and I have federal ecu's in it!!!!Thanks Mike
Q451990
That should not matter... I have a 90Cal with a 93Fed ECU... no problems there. The only difference between the two cars is the EGR temp. sensor (which is ignored by the federal ECU), and a different catalyst part number... otherwise the cars are identical. I might be concerned if you put a California ECU in a Federal car (it would be looking for the EGR temp. sensor circuit that's not there) but not vice versa.
Heath
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Q451990 wrote:That should not matter... I have a 90Cal with a 93Fed ECU... no problems there. The only difference between the two cars is the EGR temp. sensor (which is ignored by the federal ECU), and a different catalyst part number... otherwise the cars are identical. I might be concerned if you put a California ECU in a Federal car (it would be looking for the EGR temp. sensor circuit that's not there) but not vice versa.
Heath
Dont forget about the extra temp sensor under the plenum (in the Y).... Either way, theyre cross compatible.....
Q451990
Not sure if that applies to the older Q's... I'll have to check on that...
Heath
