rkreimer10 »
https://forums.nicoclub.com/rkreimer10-u31854.html
Thu Sep 07, 2006 5:46 am
you have a fuel issue not a timing issue. sounds like injector/fpr problem. time to start testing.
Pick up a gauge from the local parts store and T it into the line between the fuel filter and the fuel rail and start the car.
You should see 34 psi.
Disconnect the vacuum line going to the fuel pressure regulator and it should jump to 43psi.
Using pinch off pliers clamp the fuel line exiting the regulator, pressure should jump to at least 80 psi, if not then the pump is bad.
Shut the car off.
Pressure should hold at 80 psi, if not the pump or injectors are bad.
If it is dropping pinch off the fuel line between the gauge and fuel line, if it stops, bad pump, if it keeps going leaky injectors. move the clamp to between the gauge and rail to double check, if the gauge is stopped it is leaky injectors, if it drops bad pump.
Take off the pliers, pressure should drop to 43 psi and hold. If it drops lower than 43psi the regulator is bad, as is higher.
To test injector flow...
install the gauge as above
build a harness with battery clamps on one end, install a switch inline with one wire (momentary push button is best) and a resistor(10 ohm or 10 watt from radioshack) for peak & hold injectors, and an injector clip at the other end.
prime the fuel system (shold hit & hold 43 psi)
clip it on to injector 1. hold the button down and count how long to drop to 20 psi. Round it off to an easy number.
Repeat the following for each injector until you get a consistant number for each.
prime the system
Watching a clock hold the button down for the time you figured out earlier, and record the fuel pressure shown after each try.
If one injector is exceptionally high or low it is bad.
