How can I tell if I have VLSD?
dudealex1
Car: 1996 Infiniti I30
In my Infiniti I30 1996 non-touring how do I know if I have limited slip. I know I can do a 2-wheel burnout, but it feels like one wheel will slip on ice. Thank You
Edit: My trans. code is RE4F04A FN36. Hopefully that helps!
Modified by dudealex1 at 6:37 PM 4/5/2007
A.Tech
Car: 1998 Nissan Maxima SE Black on Black 5-speed, and yes. I know my avatar is a Gen 5... lol
All Canada Maxima ES's and I30s have VLSD...
You do have VLSD because all I30s have it... Lucky...
but remember you don't have 100% wheel power to both wheels all of the time. VLSD works a bit different from say a Posi-rear end. You will be able to use both at once in like a burn out and such but Ice is a bit different... Both use clutches and those clutches can slip if it is way too hard for the other side to move. IT is a part of the differential action, even for a VLSD.
maxhopper
Car: 02 Maxima SE 6spd
A.Tech wrote:You do have VLSD because all I30s have it...
All I30t's have VLSD.
A.Tech
opps my bad...lol
maxhopper
The easiest way to tell if you have a VLSD trans is to look at the data tag on the firewall near the passenger side of the car. If it ends with a "V", then you have a VLSD.
grey99max
Car: 1999 Nissan Maxima GXE
dudealex1 wrote:In my Infiniti I30 1996 non-touring how do I know if I have limited slip. I know I can do a 2-wheel burnout, but it feels like one wheel will slip on ice. Thank You
Sorry - the RE4F04A transmission code is for the open-differential model. The VLSD has the "RE4F04V" code... I've installed one in my '99 Maxima.
