How can i tell if i have LSD or ABS?
KoukiRock
I just got a 98(Kouki) SE. I heard there was an option where it had LSD and ABS how do i tell if i have it?
plane16j
Car: 91 nissan 240sx
look in the fuse panel and see if the abs slot is fused. if not then you probly dont have it. the other way is to go really fast then floor the brake if they lock then your s#!t out luck with no abs
KoukiRock
Ha ha ok i'll check the fuse box first. Thanks plane
311 RB26DETT
Car: 1990 240 coupe + 1991 240 Coupe
for lsd there will be a orange sticker on the back side of your pumpkin if you have that you have lsd
twistedragdoll
Car: 1996 Nissan 240sx
if you have abs then you have lsd unless the lsd was installed after the purchase of the car. on the s14 there is a metal box in the engine bay that is the abs controler. its on the passenger side near the fire wall it will have brake lines running from the MC.
KoukiRock
Thanks a lot guys... but i dont think i have abs or lsd.
94_240sx
Car: 94_240SX
I think BMC only has 2 hardlines connected if you have ABS.
got chub
Car: pearl white 95 240sx
94_240sx wrote:I think BMC only has 2 hardlines connected if you have ABS.
i think the s14 has 3 ill look in the morning
Snott Rocket
Car: 1991 240sx, 1986.5 Toyota Supra, 1974 Corvette, 1962 Rambler Classic 400
Prolem with looking at the sticker on a 10+ year old car is that they tend to fall off. Why not put the car in neutral with the rear wheels off the ground and spin the wheels? If they turn the same direction you have LSD. If they don't either you don't have LSD or it's not working properly. Oh yeah, use jackstands and turn wheels by hand. I know it's common sense, ut I watched some guys at the junk yard do this with the car running and resting on the factory scissor jack...
Slappy
Car: 1993 240 sx coupe
Jesus Christ. I cant believe people still ask these questions.
Ever heard of Google? Or the freakin search botton?
http://www.answerbag.com/q_view/13166
It took me a whole 0.18 seconds to find that.
