Bluefire »
https://forums.nicoclub.com/bluefire-u7784.html
Thu Apr 22, 2010 10:42 pm
If you unplug the iacv it should change the idle. The other way to test is to make sure the blue/white wire has 12v ign, and the other wire has good continuity back to the ecu.
Some things i've seen that cause high idling are boost leaks, high fuel pressure, and ignition timing. Another weird thing I recently saw was when someone accidentally hooked up the ficd solenoid to ign. This will immediately raise the idle.
-Bluefire
