How can I remove the tar,sound deadner, on the inside of my car?
zippitta
Car: 1990 240SX HB
I have been working on gutting my car for the last couple of days, but I found that there is a SH load of tar under all the carpet and seats. It is as hard as a freakin rock, I mean, I can barely scrape ot with a screw driver. I was wanting to get some ideas on how I can go about removing this stuff.
Thnx.
scott240sx
Car: 97 240sx
i heard of someone using dry ice then use a hammer and chisel. after putting dry ice on it the sound deadner just broke off.
240DRFT
ya i was reading drift factorys 240 build up and they used dry ice before then tried using a heat gun then said that dry ice was the best way to go
zippitta
Car: 1990 240SX HB
So with the dry ice, all I would have to do is put some on the tar and let it sit for a minute and then start chiseling?
nismo521
Car: 1993 Nissan 240SX HB
At my job, we have a dry ice blaster. It's pretty much like a sandblaster that sprays dry ice instead of sand. A lot less messy than sandblasting b/c all the dry ice just evaporates. You have to be careful though, if you have the ice chunks coming out too big, it will take paint off. I'm sure there's somewhere you could rent one from, you would just need electricity and compressed air to run it.
scott240sx
Car: 97 240sx
i forgot how long the person said they had kept the dry ice on but i think it might have been around 5 min. i quess you would just have to experiment with the time. let me know how long if you find out
need2drift
Car: 89 s13 sr20det powered coupe
I removed all mine in the winter and just used a chisel and hammer....
rico05
Car: 1992 RMS13 w/ CA18DET
I used a propane torch and a metal scraper. Took about an hour to do my trunk. Just heat up the goo for a sec, then scrape. You can only get a few inches at a time, but it comes off like butter when hot (you can pull it off in sheets when you get the edges loose)
Chingon
Car: 1991 and 1992 hatchbacks
I finished doing the fc, and while a butane torch worked ok, the best and fastest way was using an air chisel gun. I did not want to go buy dry ice, so I worked w/what I had. If using dry ice, brake it into lkttle pieces and spread all over the area to be removed and wait 15 mins.
To tell you the truth, my method was nice:
I removed trunk, storage bin, front seats and firewall tar. In other words, all of it.
Ender_Zero
Car: '03 Base Z, '91 S13 Coupe
when i gutted my FC i used dry ice for a little while, but it got to be to long of a process and just went after it with a few large screwdrives and hammers and a couple of child laborers (aka my friends little brothers) worked out really nicely.
Ender_Zero
oh btw, i went to weigh the tar that i took out of the RX7 (and some of it, maybe 1/4 of it, was thrown away before hand on accident) but it ended up weighing about 20 lbs....
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
where acn you get dry ice...i just gutted my hatch up to the front seats and want to get rid of that tar...if i acnt get dry ice locally ill just chisel it out
scott240sx
Car: 97 240sx
i have seen dry ice at walmart
zippitta
Car: 1990 240SX HB
Im not sure where you live, but Publix grocery stores sell it. If you dont have a Publix or the Wal-Mart near you doesnt sell it then try going to the grocery stores near you.
zippitta
Car: 1990 240SX HB
Thinks for all of the advice I really appreciate it. I am going to start on that first thing in the morning. I think I will use a combination ofeach of your methods...dryice, chisel, scraper, torch and some "child labor" lol. Ill let ya'll know how it goes. THNX
