How can i make this wheel flush?
Dammitboy
Car: 92' Nissan 240
92' 240SX, 30mm Z32 calipers, stock body.
Wheel is 17x9 +35 offset Drifz 505GM nos.
Thanks for your help.
http://i127.photobucket.com/al..._.jpg
a href="http://photobucket.com/" target="_blank"></a>
neverlift
buy better offset
really are they on the car yet? and are not flush or your getting them and think the wont be flush?
I would think a 9 inch rim even at +35 would be close to flush enough.
I know my rikens are almost over flush(j/k not possible even put some 5mm spacers on it to see),anyways they are only 15x7 0offset some shots are under "mmm mesh"
cmfireman
Car: '96 Nissan S14 SE
Bolt-on hubcentric spacers and longer studs.
zerothread?id=137861
zerothread?id=401
zerothread?id=216954
Dammitboy
Car: 92' Nissan 240
Not on my car yet, & +35 is all they offer. I really like these, And would like them to be flush. Here's a "rendered" pic of what they might look like, but this is a pic of black 18"s, I think they look fantastic on an S13.
Modified by Dammitboy at 1:53 PM 1/12/2007
Ca_laurier
17x9 +35 isn't to bad
just run 25 mm spacers all around that do some rolling and shazam
Dammitboy
Car: 92' Nissan 240
Here's a pic with 17" gunmetals.
chitownguy
Car: 74 260z and 85 325e
15mm spacer
AmoebAssassin
Car: 1991 Base fastback 5spd, black
a 20mm spacer, some sweet camber, and some fender remodeling will make those babies flush as your toilet. Blang Blang!
Dammitboy
Car: 92' Nissan 240
thanks guys
Glyph
Car: 1993 Nissan 240SX Converible
gunmetal for the win in my humble opinion.
chitownguy
AmoebAssassin wrote:a 20mm spacer, some sweet camber, and some fender remodeling will make those babies flush as your toilet. Blang Blang!
Indeed I was just being conservative.
onosqv
Car: '92 240sx Vert
Did you render the pic yourself? that's HOT!!!
A couple things you can do... if you run almost no camber in the rear (say just .5 negative), that will help out a bit, running a fatty sized tire so it doesn't look as tucked, then just a tiny sandwich spacer possibly (around 4mm-8mm if you are running stock studs), you'll be pretty close to "flush".
Flush is relative for most ppl, so all depends on you.
Camber settings do a lot tho.
When I had 18x9+20 w/ some stretched tires (225/40), they stuck out of the fenders a good 1" or so, increasing camber to about 2-2.5 degrees fixed that right up... so in your case, not running as much negative camber would "push" the top of the wheel out.
It could work, you just gotta make it work, GOOD LUCK!
AmoebAssassin
Yeah, you could run zero camber if you want your car to handle like trash.
foamcup
Car: Nissan's
how did you do that picture? I mean what program and is that all you? if so, you're the man haha
onosqv
Car: '92 240sx Vert
AmoebAssassin wrote:Yeah, you could run zero camber if you want your car to handle like trash.
about -.5, like I suggested if he wanted to go the "playing w/ camber" route, would still be w/in stock specs .
Dammitboy
Car: 92' Nissan 240
foamcup wrote:how did you do that picture? I mean what program and is that all you? if so, you're the man haha
Thanks for the help guys, I'm teetering back & forth on what to do. I've got a 5 lug conversion ready to go for those wheels, but for sheer simplicity, thinking about doing some 17x9 +20 4-lug FN's. I know those will clear Z brakes.
I made that pic with this- http://www.wheelenvizio.com/?wheel=Envizio
Really fun site.
Kevin
foamcup
Car: Nissan's
YES! My new favorite site!! thanks!!
