How can I make a stronger(NA) KA24 in California.
TrukillaS14
Car: 95 Nissan 240sx w/97 Ka24de w/VLSD
I kno I kno, I should move cuz California is hella strict on mods and stuff. But I just want to tune up my 97 ka engine. What are some ways to boost its power without getting a turbo, or a shot of Nitrous. I am planning on turbo later though. I'm a noob and yes I admit it ok. I am taking automotive class right now, I kno a quite bit about cars but not in knowledge of tuning wise yet. I'm buildin my 240sx for drag. Thanks ka24de 170,000 miles
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
Only significant bolt on's for OBD2.You could do the 240/248 cam swap from the OBD1 engines.Add a magna FLow high Flow CAT for OBD 2 engines.ECU emulation/NISTUNE ecu.2.5" or 3" exhaust, more likely to pass dB testing with am 2.5" exhaust.Bore the throttle body to 64mm, port the manifold for that bore size.extrude manifold runners from 44mm to 45mm diameter.Iridium spark plugs for less ignition foulingAEM intake pipe (CARB Legal)NISMO radiator capelectric fansaluminum fly wheelaluminum drive shaft
LambJerky
Car: 1995 240sx
Bigvinnie wrote:NISMO radiator cap
This produces more power?
TrukillaS14
actually not to be mean but yes i kinda does my shop teacher told me new stuff even though its does seem likely to give power it does
TrukillaS14
sweet thanks how much power increase will that be. I kno stock is 155hp. and do you think any thing else can help. OH yea they wont crush my car for all that s*** will they? The CARB sticker will help but wat bout the others?
Bigvinnie
maybe some where around 195HP or about 155~160 to the rear wheels.
seang
Car: Ford Fiesta ST
Funny thing about the radiator cap, I took half the spring out of my stock one so it holds like 1 psi, and I havent noticed any losses at all.
LambJerky
Car: 1995 240sx
TrukillaS14 wrote: actually not to be mean but yes i kinda does my shop teacher told me new stuff even though its does seem likely to give power it does
Not mean, I was asking a serious question.
TrukillaS14
also why a 240/248 instead of a 240/240, I'm still learning so thats why I'm askin
Bigvinnie
TrukillaS14 wrote:also why a 240/248 instead of a 240/240, I'm still learning so thats why I'm askin
That way you don't have to waste your money on cam gears or buy and extra set of teh same cam. 240/248 is proven to work better with the G70 MAF, then it does with the OBD1 G60MAF, and SCV's.
Bigvinnie
Yes the purpose behind a higher rated PSI radiator cap is to raise the coolant boiling point. This way the coolant will transfer more heat reducing engine temperature allowing the engine to be more efficient, creating more power.
FYI you don't need to spend lots of money on one of these radiator caps, the standard 300z radiator cap will work just fine on s13 and s14 radiators.
TrukillaS14
for the flywheel is a fidanza fly wheel better than an aluminum
gumby74
A friend of mine in Sacramento is running a lightweight flywheel from Ebay on his SR. He has used it with no problems and is on his third clutch set in about 5 years. I ordered the same one (KA unit of course) for my car. It is the F1 racing piece and I paid under $200 for it including shipping. I had my local machine shop check the flywheel for trueness and balance, and it checked out perfectly.
If you have the space though, I would pick up a junkyard block and do a high compression rebuild. Which is what I did. Bored .20 over and using factory KAE pistons. I will be picking up some BC stage 2 cams here before the end of the year, and adding a small T25/T28 based turbo set up shortly thereafter. Right now I am collecting the pieces.
TrukillaS14
where can I get 240/248 cams
Bigvinnie
TrukillaS14 wrote:where can I get 240/248 cams
Junk yard 91-94 240sx's
thrasherx89
Car: 90 hatch (91 dohc, tein, z32, ss, injen, energy, b &m)
oh snaps i saw somebody mention sac town!
haha i hail from here too
anyway, putting my 2 cents in
if you want to make more power to the wheels for the ka and have it still PASS SMOG i would add to the list
performance clutchgood ignition timingpulleysbetter quality gaslightening the rest of the car (lol)
not sure they make carb legal headers...hmmmmm
all coupled with proper maintenance
i wouldnt suggest a cam swap because from what ive experienced the cars dont pass smog that well with a cam swap even though im sure its possible
good luck
p.s. anybody else representing sac. hit up the cali region forum and look for info on our meets
Bigvinnie
thrasherx89 wrote:not sure they make carb legal headers...hmmmmm
DC sports header is the only legal header for 91-94 ka24de's
pella
Car: 1995 240sx S14
thrasherx89 wrote:oh snaps i saw somebody mention sac town!
do you have the link? cant find in search
biggie
Holy year old thread...
font-color-orange-california-region-font.html
