*Braille instructions available via PDF download at http: //www. f5air. com/.gatorglaze wrote:You didnt buy the filter by itself did you? You need the entire intake. And if you bought it it should come with instructions that Helen Keller could follow.
WOW...just WOW...you need the pipe bro. The intake has the mounts and place where the MAF screws into. Go back and order the pipe.sntfloo wrote:(I don't have intake I just have filter)
i thought you knew it was from there new line of hover filters. they kinda just.........sit in place....and....hover?gatorglaze wrote:What the hell are you going to do with a cone shaped filter in an airbox that uses a rectangle filter. Your trying to put a lego piece onto a knex set.
+17 HP EASILY!
