the_invisible »
https://forums.nicoclub.com/the-invisible-u5272.html
Tue Jul 29, 2003 9:00 pm
shocks and lowering springs do very little in improving the steering feel of the car. as does rear suspension upgrades.
if you want solid, in the brain, kind of response, here is the list of what i have:
- Moog tie rod ends (OEM heavy duty replacements with urethane instead of rubber insulator on the joints)- Moog tie rods (with urethane instead of rubber and steel insulator) - Moog ball joints (for s14 only)- Energy Suspension front lower arm bushings- spherical bearing T/C Rods- Nismo power brace- front strut tower bar
After these are done and you want to improve the steering even more, get suspension with solid upper mounts and better front sway bar.
