.opilla36 wrote:You get a high low converter and plug into the negative and positive from the stock amp. The high low converter has RCA connection coming out the opposite end. Connect RCA's to aftermarket amp and to the high low converter. Easy as that. Then just connect amp to battery and ground and you have an amp with subs. Thats the way i have my set-up done. 1000\1 JL Amp w/ 2 10" W6 enclosed. Sets off car alarms!
Its Under the driver seat. Easy to access from the back seat.Alegre323 wrote:.
sweet where is the stock amp located?
