How can i get more leg room?
drockscustoms
Car: 240sx s14
I have an s14 and i have long legs so i get a little cramped after a nice long drive. Is there anything i can do like go with different seats or move mine back some how so i can get more leg room
plane16j
Car: 91 nissan 240sx
cut a 1'x2' hole in lower portion of the fire wall. that'l do the trick.
bone_stock_240
Car: 1995 Infiniti Q45
There is a little handle underneath the seat that when you pull it up, will allow you to move your seat further back. It is pretty cutting edge stuff. If that does not work, completely remove your driver seat and drive from the back like an OG
plane16j
dgms240
Car: '90 s13 hatch ka24det
leg room shouldn't be a problem especially in the s14. trust me i should know im 6'6. i've got plenty of legroom. head room however is a different story. anybody know if there are any lower seat brackets that will work with the stock seats?
plane16j
im 6'5 in a s13 i got no problems either way ....well maybe head room somtimes when you hit a big bump...
adrianfromthecastle
Car: 1992 Nissan 240sx
bone_stock_240 wrote:There is a little handle underneath the seat that when you pull it up, will allow you to move your seat further back. It is pretty cutting edge stuff. If that does not work, completely remove your driver seat and drive from the back like an OG
Boostedrex
Car: 04 WRX
custom bracket lo or maybe sliding your seat back
480sx
Car: 1996 Pearl White 240sx
+2 lmao
180fan
Car: 89 fastback
bone_stock_240, again I must tip my hat to you. However, as a moderator, I have an obligation to also give not just you, but everyone else a friendly reminder that we could all take it a little easier on the folks if there was any offense taken by the other party.
