how can i drop my j30
alex5macr
Car: infiniti j30
i have an stock j30 and i want it to look a bit more agressive i wanna drop it but i don't know how much can cost or where to buy a set of coilover or lowered springs. somebody know something that can help me?
thanks for the time
ProudNissanFreak
Car: 2005 Imaginary WRX STi, 2003 Civic
Lowering springs/coilover kit is your best bet. DON'T cut your springs, it's cheap and easy, but unsafe. You can check out our advertiser's here: http://www.nicoclub.com/archives/nissan ... icing.html and see if they offer lowering kits for your car. Also, you can search (bar here--->) to see what kits other members have used.
alex5macr
Car: infiniti j30
thanks bro
alex5macr
Car: infiniti j30
bro i didn't find any lowered kit for the j30 there i looked everywhere and nothing for the j30
driverdriver
Car: NICO's longtime resident Canuck!!!
They're isn't an actual lowering kit you can buy and direct bolt on. People on this board have bought lowering kits for Maxima's and 240sx and custom fabricated them to fit the J.
alex5macr
Car: infiniti j30
oooo damm that's a lot of work to lower my car right?
xxcrashxx
Car: 95 Infiniti J30
yep, thats a lot of work, possiably metal fabrications, or just paying big dollars for premium aftermarket shocks. could try hitting up ur local junkyard and pull a pair to try to cut, so that if something goes wrong, you still have ur stock springs.
alex5macr
Car: infiniti j30
i found a web page where they say they sale lowering springs for the j30 they say that they are universal but i dont know
look this link
http://www.ilovebodykits.com/category/1 ... rings.html
swimshark
Car: Bamboo Mist 1994 Infiniti J30 Soon to RIPs
Pearl White 1993 Infiniti J30 Project Ghost
new-idea-found-for-front-suspension-mod ... 87287.html
rear-lowered-and-tt-sway-bar-installed-t468330.html
those were my routes. ive changed it up a bit though since then with a few better parts to adjust camber and have added 20mm spacers with longer wheel studs to get the wheels out more.
the adjustable rear upper control arm is a must have when you drop the rear because the neg camber increases the further you drop it so these help to take it back to stock spec while getting a drop. fronts you will end up using the camber plates on top of the shock. i picked up a pair of EVO VIII Tein camber plates for mine.
krazy skwerel
Car: 1989 240SX Coupe down for the count
2005 Honda Accord
1974 Ford Mustang II
Sorry to bring this thread back but I have some questions. I don't want to go crazy and slam my j30. I gather that stock Z31 springs will fit the front and it should be about a 1.5" drop. My problem is finding stock z31 springs and also what to use for the rear. Did the evo front camber plates fit in the stock holes or are you still rocking the modified holes you made for the s13 coil overs? Any help would be greatly appreciated.
swimshark
two of the holes for the evo 8 camber plate line up and you have to drill an adjacent hole to the third by maybe 1/4" or so from the 3rd hole. i can get a pic later on of it. as for springs see if you can just buy a pair of 300zx z31 springs online. the guy i bought mine from doesnt stock them anymore. i still have my pair but still waiting to hear from someone that has been wanting to purchase them from me. the rears i never got to messing with. i do have a pair of tein r32 coilovers that i am selling. its the only route i used to lower the rear. sorry i got lazy and didnt research what fit stock J30 struts.
