How Bout Manual boost controller
goixiz
Car: Cycling and cars
I dont race just driving my sr20 on an S13 dailySo will a manual boost controller be OK ?I dont plan to go over 10 or so PSI Everything i plan is stock
Anything bad about manual boost controller
Im goin the Budget route
Whos got one that is good
I H8 UR DSM
I use the Turbo XS manual boost controller on my car
http://www.rollhard.com
JJ240
Car: 95 white 240
The Joe P. MBC is great. We installed it on my friends civic last week and it holds within .01 bar at 8PSI. No spiking at all.
JJ240
Car: 95 white 240
vapor_skank
dont manual boost controllers hold the boost better than all the electronic ones ? just wondering....
240_Keyy
Car: '90 240 Fastback
I have the Joe P MBC on my car and it works splendidly. Holds 12psi with no spiking whatsoever. Good for cheap, but I will still upgrade to an electric when I get bigger turbo...
goixiz
240_Keyy wrote:I have the Joe P MBC on my car and it works splendidly. Holds 12psi with no spiking whatsoever. Good for cheap, but I will still upgrade to an electric when I get bigger turbo...
Can you please take a pic of how you connect them (if you have stock IC and turbo)
240_Keyy
I don't have stock IC or piping. I have it connected between the HT hotpipe and the wastegate solenoid...
JJ240
Car: 95 white 240
well IC piping doesnt really matter. You put it where your vacuum line that went to the wastegate previously was. If you have a tial wastegate then ignore the top connection.
