mod_mastaz »
https://forums.nicoclub.com/mod-mastaz-u62511.html
Wed Jun 11, 2008 4:21 am
What about running a 20e crank/rods(aftermarket) in a 20e block, with custom pistons and 18det everything else? I thought about just a straight head swap, but the work involved in the timing gear and belt pushed me away. As for those that say the 20e block is weaker, I don't think so. The 20e and ET share some of the same accessories and they look almost identical with the exception that the 20e block is longer. For those that don't know, the ET and the DET block is identical, minus a few things, like the oil squirters and idlier pulley which don't have the holes drilled out for it. If anything, you could block fill it up to the water drain plugs like the V8 guys do.
As you can tell, I thought a lot about this haha. If only there was a solution for the timing components. I've mixed and match my share of suspension and electrical parts. When it comes to engines, I'm not confident or knowledgeable enough to mess with something as important and expensive.
Edit: I meant water freeze plugs. Oh and I was thinking about a boosted 20det BUT a 18det is more than enough for my power goals haha. Either way, it was a fun idea to kick around.
