how bad is this?
nghtrain88
Car: 1991 Nissan 300ZXTT
i have all my fuel hoses disconnected to change out the injectors.. long story short, had to put my power window up for incoming rain so I hooked the battery back up and switched key to On position and fuel came pouring from one of the hoses right out and onto a towel i had laying over the lower intake that the plenum sits on.. this was yesterday and still smells like fuel today.. will it dry up and not be a problem? or how screwed am I
Milo (San Antonio)
Car: Project LOWFATZ (weight reduced slicktop TT)
should be fine, you just engaged the fuel pump when you turned the key on. You should have removed the fuel pump relay to make sure that didn't happen.
nghtrain88
okay.. just thinking about it again, the fuel should all get combusted anyways.. and yeah I removed the relay to relieve fuel pressure but put it back in.. i'll know to leave it out until the end next time
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
You'll be all right, it happens. Now you know for next time
