codyace »
https://forums.nicoclub.com/codyace-u28194.html
Wed Mar 10, 2010 7:43 pm
Proper PCV and Catch can setup:
Rear Block Vent to OE oil air seperator.OE oil air seperator to Valve Cover T (one side)Valve Cover T (other side) to Catch canCatch can to intake pipe
(and then obviously PCV valve to intake manifold on the back passenger side of valve cover)
Whoever said that oil vapor sucked into the setup will hurt performance or lower octane and or be bad is an idiot. Catch cans are baffled and or filled with wire mesh for a reason...
The above method is best for emissions, and performance. Certainly a custom valve cover with custom baffeling can replace the OE oil air seperator aspect of things, but you want quick and easy, this is the way.
A valve cover T just isn't the best for performance, and often time allows oil to spray all over from sloshing around. You also loose the vacuum over the top end of the engine aspect of things too.
Not the best pic, but you can see how it should be routed
