how bad is it for the e-brakes?
Nissan dominates the drift scene - Always has, always will.
mkg12
how bad is it for the e-brakes when u pull them up for something like a e-brake drift or something?
i mean it shouldnt do any or much damage i would think.
Chingon
Car: 1991 and 1992 hatchbacks
not bad at all....
j/k i don't know. new shoes (best scenario)
silkk
Car: 94 B13
89 S13
07 S2000
it'll only wear out the pads and your tires.. i think.
SHIFTrl240
Car: 1990 SR20 Sil-80
2009 Yamaha RoadStar Warrior
2017 Alfa Romeo Giulia Ti AWD
it eats at the muffler bearings too :rolleyes
black_s13
it defenitly kills the shoes, well if you have the entire rear swapped with a Z32, cause stock 240s done have shoes, its all discs. muffler bearings and blinker fluid may be destroyed as well.
Fenvy
Car: 2005 350Z Base 6MT
I don't know why but ebraking on my 240sx doesn't seem to do **** for me, either I'm doing it wrong or it's because it's a rwd
works fine on my integra though (fwd)
mkg12
wouldnt e-braking wear the rears pads just as much as braking with the pedal wears the front ones?
whats blinker fluid?
black_s13
you dont check your blinker fluid? oh ****... i would do that ASAP.
Chingon
damn...so the rears are not shoes on stock 240's?
Fenvy
mkg12 wrote:wouldnt e-braking wear the rears pads just as much as braking with the pedal wears the front ones?
I think he was jesting about the blinker fluid
themadscientist
240s have a machanical cable tied into the rear disks for a parking brake. S13s, not sure about S14s.
Blinker fluid is an electro luminesent fluid in JDM side blinkers, electricity passed through the light causes it to glow and brighter than standard bulbs.
No wait I just completely made that up, so sorry! Hey anybody want to hear my red car is faster theory, woo hoo hoo:crazy
Iwant240insteadofP/U
but the red car IS faster...
PhaneSoul
Car: 89 Nissan 240SX SE Black 5spd Wrecked
95 Nissan 240SX SE Green 5spd s14.5 yay!
lol, mines faster.... the black paint gives it over 550hp.... beat that sucka's... and my crack in my dash adds another 105
Mr1der
SHIFTrl240 wrote:it eats at the muffler bearings too :rolleyes
back in the cave troll!
it shouldn't do anything really bad, other then wear out tires.
just knife the clutch instead:D
180fan
Car: 89 fastback
PhaneSoul wrote:lol, mines faster.... the black paint gives it over 550hp.... beat that sucka's... and my crack in my dash adds another 105
easy, the song Kyle's mom's a bi%ch playing instantly give me a shot of nos that'll make Ludacris in 2f2f wanna slap himself with his jerk off hand! You suckas got served!
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
Please, no bad movie puns.
Dystopia
Car: Nissan S13
no the side brake as its called is great for maintainign and controling your slide.
Luke
Loveless wrote:I don't know why but ebraking on my 240sx doesn't seem to do **** for me, either I'm doing it wrong or it's because it's a rwd
Poor Honda boy, j/k
Try pushing the clutch in before you try to lock the rear wheels up ;) What stops running if the clutch is engaged and the drive wheels aren't moving? (I hope you don't have an auto)
Anand
Car: 95 Nissan 240SX
Luke wrote:Poor Honda boy, j/k
LOL, I was just about to say that... press the clutch in all the way and then pull the breaks...
Also try warming up the pads before you actually try to lock up the rears...
spec-u-later
Car: Yaris...FML
Remember to hold in your clutch when you e-brake or the motor will work against you.
Dystopia
Car: Nissan S13
you can als convert the reaer to hydralic brakes, ebrake that is
mkg12
soooo it sounds like it doesnt matter really
except if u care about ur pads or tires
and u know what adds more horsepower then paint or a cracked
dash??? DECALS AND STICKERS!!!!!! DONT U JUST LOVE
THOSE "NITRO" STICKERS?? i mean it adds around 75 horses
right???to bad there car doesnt really run on alcohol those idiots
that dont know what nitro and nitrous is
Chingon
Dystopia wrote:you can als convert the reaer to hydralic brakes, ebrake that is
the rears are hydraulic...the e-brake is mechanical....
Unless there is a weird way to have hydraulic e-brakes and retain pressure somehow....
BuudWeizErr
Chingon wrote:the rears are hydraulic...the e-brake is mechanical....
Some rigged up line lock system could do it, but cable setup works fine.
I use the ebrake midslide if I think I'm going to come too far around to catch the rear. But it also helps for getting around very tight corners.
And yes, if you're not pushing in the clutch before you yank your ebrake, all you are doing is wearing your rear pads. If you are using aftermarket pads (ex: hawk, axis, etc) they may work better when warm. Drive around for a minute with your ebrake up slightly. Not so much that you can't drive, just so they are touching. Then use it to initiate and see how it does as opposed to cold.
Anand
yup, just pull your ebrake up like 2-3 notches and there you have it
Oh and this goes for generic pads too... bcause I have them and they grip much better when they are warmed up...
daniel
hahahha
just gank that ebrake.its fun..
anand
all pads work better when they are in their operating temp =)except for
hc titan kaithose **** grip even whent hey're frozen haha
Dystopia
Car: Nissan S13
i am going to steal a post from Daniel on another board....
Quote »
Here's what you want to do for a hydraulic ebrake
1. get a spare clutch master cylinder 2. disconnect and remove all your old ebrake cabling 3. disconnect rear brake line at the tee and then you're going to want to move that brake line into the old ebrake lines position 4. now you're going to want to take a section of something like 3/16" line and run it from the cab to where the old ebrake used to be
okay now that thats all set up, just get a few brake line adapters and hook them up to where the res used to be so you can hook up the line to the c. master cyl.
now, run a line from teh brake master cyl into your extra clutch master cyl so that its
BMS--->CMS2--->REAR BRAKE
you now will have a hydraulic ebrake that will lock the rear wheels from the caliper!![/quote]
daniel
cool
dont make mention of that other board.=)lets keep that one quiet.
Phax
Car: Control dynamics
I use my ebrake all the time. You have to be aware of how hot it gets. I have Hawk HPS pads, and the brake stops grabbing quite so well after a couple of strong applications.
Dystopia
Car: Nissan S13
i wont dan... i want to keep it how it is....
this is catharsis BTW
Return to “Nissan Drift Forum”
