How bad did I screw up the alignment?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
cfauvel
I jacked up the car and placed the jack stand on the rod section of the STAY ASSY-COMPRESSION ROD,LH part number 544C5-AL501
As I started to drop the car on to the jack, I saw the the rod wass being bent and quickly stopped the full drop.
(how do you attach a picture?)
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
well, if its bent you most likely will need to replace it
telcoman
cfauvel wrote:
Wed Dec 05, 2018 8:17 am
Why didn't you follow the vehicle lifting instructions in your owners manual and the FSM?
See page GI-30
https://www.nicoclub.com/FSM/G35/Sedan/2008/GI.pdf
Telcoman
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
