creophus »
https://forums.nicoclub.com/creophus-u4650.html
Tue Jul 06, 2004 6:57 am
I think my car over heated because the upper radiator hose came loose. I was running the stock KA radiator and I never had a problem with it running hot as long as the hose stayed connected.
Well I'm driving along at highway speeds, not pushing it too hard and when I get off the expressway I see smoke. The temp gauge didn't go up, but when I stopped there was smoke everywhere. The car also felt like it was loosing power. The plastic coupling on the endtank had broken and that's why the hose worked it self off. I had it towed home and when I filled the radiator I noticed a bad leak around the water pump. I don't know if its just the seal around the water pump, but I'm prepared to replace it if necessary when I get a new aluminum radiator.
My question is...how bad can this be? Do you think that it's possible that I warped the head or blow a headgasket? I started it up just fine for a few seconds and there was no smoke, but again, there's a bad leak around the water pump, so I don't know if it has enough coolant in the head to smoke.
What should I plan on replacing other than water pump and radiator? I already have dual electric fans...that's why it stayed cool with the stock radiator. Your help would be greatly appreciated.
